Why is some concrete so white?
I'll having some concrete work done in the near future (driveway, curb, apron) and want it to be a nice medium to light gray color. There has been a lot of concrete work in my community and most if not all of it is very bright white. I do not like it this bright, as it stands out too much and is harsh on the eyes. Is something being added to the mix to make it dry so bright? What do I tell my contractor so that I can ensure my driveway does not look this way?
Does the contractor own his own mixers & stone yard? If not he will have to hire truck to pour the concrete. Any time that I worked on a crew, I never saw a special color ordered.
What you might be seeing is a curing compound that's sprayed on the concrete after placing and finishing. It's white to reflect the sunlight and keep the temperature of the concrete lower for a slower curing time. The concrete will eventually revert to a typical grey color over time.
There are a lot of curing compounds out there that are clear. Frankly, it's only on commercial/street projects that I've seen the white stuff used. I've never paid any attention to how long it takes for the concrete to turn grey, I just know it does.
You want concrete to cure as slowly as possible for optimal strength and durability. IMHO, covering fresh concrete with burlap and keeping it wet is the best way to cure, but that's rarely seen any more, at least around here. I would have your concrete guy use a clear curing compound, then lightly sprinkle the concrete with water as much as possible to keep it wet for at least 3 days.
