How to get rid of basketball pole with concrete in it?
My sister and I are getting our family home ready to sell and one of the projects was the basketball pole/goal behind the parking pad. She hired a company to remove it, but all they were able to do was pull off the top part, leaving us with about 4 feet of pole still in the ground. No amount of sledge hammering seemed to break of the concrete in the ground, and truck-pulling with a chain only broke the pole at the level where it had concrete inside.
Now my sister wants me to get someone to saw the pole off at ground level and just cover what's left with mulch. Is that even possible? Will a reciprocating saw be able to do that? And would the metal blade work once you hit the concrete inside? Or is there some other way to just cut it off?
Thanks,
Lefty3
Thanks,
Lefty3
Use a reciprocating saw with metal blade to deeply score around the metal pole and then hit it with a sledgehammer.
(or..... have the wife back over it)
Or an angle grinder, with which you might be able to get a tad bit deeper with the same amount of shoveling. If you can get it down 5-6" you should be able to get grass to grow over it, and, depending on where you are located, it's getting pretty close to the time for fall seeding, so you could blend it in a bit better than having a small patch of mulch.
I took out mine this spring and used an air chisel to take it down 6" so grass would grow. Assume you dont have a compressor then a small electric jack hammer from rental store.
You will not be able to break it up with sledge hammer, too big, solid of mass for hand tools!
