Installing Wood frame posts into cinderblock holes
Old 08-31-17, 03:06 PM
P
In my chicken coop design I have made a concrete footer and laid 2 courses of cinder blocks at the base (to contain the droppings/compost mix). Now I will be installing the wood frame on top of it.
My idea is to put 4x4 posts into the cinderblocks in each corner, fill it up with cement, and then build the frame around that.
Would this work? Is this something that people do? or is there an alternative easier approach to my situation?
(imagine the image has 2 courses. I added another stack before I took the picture)
Old 08-31-17, 03:12 PM
Received 361 Votes on 318 Posts
Welcome to the forums!
It would make more sense to mortar/concrete in tie downs or even a metal strap. Even though it's pressure treated the 4x4 incased in concrete will rot over time.
Old 08-31-17, 03:40 PM
W
Received 22 Votes on 21 Posts
Framing chicken Coop
Anchor J bolts into the top row of blocks and use the J bolts to secure a bottom plate for your framing.
XSleeper's Avatar
Received 790 Votes on 727 Posts
A more standard method of construction would be anchoring a treated 2x8 plate on top of your block. You would need to slug at least 2 of your CMU holes per side and set anchor bolts (L-bolts) into the wet concrete. This is usually done no farther than 12" from each corner and no farther than 6' on center. Leave the anchor bolts protrude above the block 2 1/4". After they have set up you drill holes in your plate, drop it over the bolts, add washers and nuts. Then you have a surface to frame on top of.
Old 08-31-17, 03:45 PM
When I said tie downs I meant the J bolts - couldn't remember the name
Old 08-31-17, 08:01 PM
P
I appreciate the help Marksr, wirepuller38, and Xsleeper!
It's pretty amazing how you guys take the time to help a stranger out.
Thanks again.
