Planning new paved driveway - need help not getting ripped off
Old 09-12-17, 02:22 PM
Exclamation Planning new paved driveway - need help not getting ripped off
Hi,
Our driveway is now 50 years old and believe it or not, is kaput.
I plan to get quotes to have it replaced so here are some questions:
  1. How do I know that I am getting the depth of gravel promised?
  2. How thick should the gravel be?
  3. I've seen some driveways left in gravel for months before paving and others paved immediately. Why one way or the other?
  4. How thick should the pavement be?
  5. Anything else I should be looking out for or asking about?
Thanks guys!
Old 09-12-17, 02:29 PM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
I will answer #3 for you. Settling! If you are able the live with a gravel drive then letting the gravel and stone settle for a year or two is a good thing. My father-in-law did this with both a concrete drive and a blacktop and never had problems ever.
#2. I think 4" is minimum, but I'm not sure.
If you're getting a blacktop, I suggest a brick curb level with the finish topping. It will preserve the sides for many years.
Old 09-12-17, 03:07 PM
Thanks, Norm201. Hopefully, I'll get some more answers. FYI - here in Jersey, I've never seen brick driveway curbing, just Belgium block, which is never flush, which we do not want, and which they make the real money on.
Old 09-12-17, 03:53 PM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
What type, blacktop or cement?
Old 09-12-17, 06:17 PM
Oops- I thought I said blacktop.
Old 09-13-17, 06:28 AM
Received 24 Upvotes on 19 Posts
Watch them pour it and measure
I believe 4" is the norm
If you're replacing an existing driveway, then I don't think you need to worry about settling.
Watch them like a hawk and be sure they do what they say they are going to do. Make sure the contract states the amount of gravel and the amount of asphalt that will be used, and make sure that is what you get.
Old 09-13-17, 06:52 AM
Marq1's Avatar
Find a good company, there are lots of references out there and you will be ok.
For blacktop 4" is the norm, key is drainage and solid base.
One house was all sand, good drainage but after a couple of years the drive was wavy.
Last two home I contracted, 8" of compacted gravel base, good slope, they were perfect!
Old 09-17-17, 03:56 PM
Received 1 Upvote on 1 Post
Also, the best asphalt driveways are laid in 2 layers. 1st a binder course of about 3" is laid his hands larger stones in it and is stronger. Untapped of that a finish layer is laid of approximately 1'. This has finer aggregate and will make it smoother surface less susceptible to water intrusion.
Not all asphalt contractors do it this way but the better ones do.
Old 09-17-17, 04:11 PM
Norm201's Avatar
msradell is correct. Sometimes just the binder is left for a year or several months then the 1" top coat is applied.
Old 09-18-17, 08:42 AM
Marq1's Avatar
I have never seen a two step installation for home drivewasy, might be a regional thing or they are using appropriate for a single application.
