Garage concrete repair advise
Old 04-02-18, 08:39 AM
Received 1 Upvote on 1 Post
A few years ago my garage floor started to flake and crack where it slopes down to our driveway. It seems to be in certain areas. I believe that it's due to the snow melt from our vehicles, it pools at the garage door, freezes and then melts.
I mixed some generic cement and filled it in, it last a winter or two but this year it is worse. I want to fix it the right way as it is getting deeper.
What can I do to correct this problem the proper way? What materials?
Here are some photos:
https://c1.staticflickr.com/1/786/40...ade9e82c_k.jpg
https://c1.staticflickr.com/1/901/27...4d82eb2f_k.jpg
Old 04-03-18, 11:21 AM
Received 3 Upvotes on 3 Posts
Have you tried hydraulic cement?
Old 04-03-18, 12:01 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Unfortunately there really are no good, long term, patching materials.
They make some epoxy patching materials but winter freeze thaw and salt runoff are going to be tough to overcome.
Old 04-06-18, 04:34 PM
chip down to sound conc,, make certain the patch area is extremely clean, repair w/polymer-modified mtl from the apron/vest store,,, no epoxy rqd,,, fairly easy fix ,,, depending on what you buy ( we use cement-all), you may need some dark grey pigment avail from sher-w,s - use the wtr-bas'd latex colorant[,,, freeze/thaw won't be an issue
Old 04-16-18, 10:52 AM
Hi, I think part of the problem that I had, or most of it, was that I did not properly treat the area by removing it, watering the area or cleaning it, and using cheap cement.
I want something that will hold up, are you saying that Cement All is a good product vs Epoxy resin?
Old 04-16-18, 04:48 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
I have had very good success with a cement repair product called Top'n Bond.
It wont last forever but I have extended the life of several different concrete surfaces.
