Sidewalk repair
Old 04-14-18, 12:43 PM
W
Received 35 Upvotes on 33 Posts
Sidewalk repair
My wife can't back the car up straight without running over a corner of a sidewalk that is near the driveway. The corner of the walk has cracked and broken up into pieces now that I could easily remove and pour in some quickcrete, but I want to anchor it to the rest of the existing walk slab if I can. I know I should pour a new complete slab, but we are talking feet of concrete rather than inches if I cant attach or reinforce the repair properly. Opinions?
Old 04-14-18, 12:50 PM
XSleeper's Avatar
Received 1,696 Upvotes on 1,522 Posts
If the concrete is thick enough, you can drill holes and pound some short pieces of #3 or #4 rebar into the existing concrete, (roughly 12" on center) then tie rebar perpendicular across the tops of those short pieces. Then repour.
But the existing concrete should be at least 4" thick and in good shape. If it's weak, it might just break out even more when it is driven on again.
Keep in mind your new pour will need control joints. If your new strip is 2' wide, you should place control joints no farther apart than 3'. Lineal pieces of rebar or mesh will help keep the concrete from shifting at every joint.
Old 05-02-18, 05:23 PM
Received 1 Upvote on 1 Post
better his bride learns to use mirrors
Old 05-03-18, 03:36 AM
Received 738 Upvotes on 645 Posts
Be aware that in many jurisdictions the sidewalk is 'owned' by the gov't and subject to their specs.
Old 05-03-18, 07:57 AM
W
Concrete Sidewalk
As for driver training, I gave up on that after 50 years, still cheaper than a new one,
The sidewalk is definitely mine, but thanks for the warning....
