Tiles on front porch weeping
Old 04-29-18, 02:53 PM
L
hello.. need help..
i have a photo. I hope this works.. front deck tiles are leaking white material which cannot be removed by any method I have tried. Can you HELP !!
http://www.wtv-zone.com/thanky/porch.jpg
things I have tried to remove itTried Lime Away, Double strength vinegar, pumice stone.( destroyed pumice stone but the hardened weepage remained.) also baking soda and vinegar.
would muriatic acid work?
Old 04-29-18, 03:35 PM
L
Old 04-30-18, 07:08 PM
L
Muriatic acid helped. Why did no one respond.
Old 04-30-18, 08:21 PM
czizzi's Avatar
Really not enough information was provided. Just a picture, not real history, or anything like that. Was just a stain in a picture. For direction would have had to have before and after pics, a progression time line of decay. A honest discussion about possibilities, etc.
Old 04-30-18, 10:11 PM
T
Received 40 Upvotes on 33 Posts
You said muriatic acid helped. did it take it off or only help.
And it is not unreasonable to wait a couple of days for a reply.
Old 05-02-18, 06:04 PM
L
Thank you tightcoat,..and czzizi
..my bad.
I Thought I had provided sufficient information..and photo.
i would have answered any questions of follow up which anyone might have had, but no one volunteered to pursue the question further. thats ok. It was a few days I waited.finally frustrated I just went and got the acid and plunged ahead.
muriatic acid btook it all off. I used the muriatic acid full strength..dabbing it on with a paintbrush, letting it bubble and react to the lime like scaly stain. And then I used a scrubbie pad. Did this three times to remove a bit at a time.
I came back to post my results to help others who may have encountered such like problems.
many thanks.
o
Old 05-02-18, 06:49 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
Since the acid often soaks deep into the grout, you may experience further problems (staining and/or disintegration of grout) due to using it full strength and if you did not neutralize it with an alkali wash or at least an AWFUL LOT of water rinse. You should never use it full strength. Hopefully that will also help anyone who reads this thread in the future.
Old 05-05-18, 06:23 AM
L
Did wash it with an awful lot of water. Also, did not apply it to grout but only to stain
Old 05-10-18, 03:36 PM
L
Looking excellent. finished off job with SOS pad
