repairing cracks in concrete swale
Old 01-19-19, 08:23 PM
There is a concrete swale next to my old house and a section of it has developed some cracks. Many of the cracks are fine with a few larger 1/8-1/4" ones. I'd like to find an easy way to stop any water leaking through the cracks. Appearance is not an issue, right now I just want to do something before the next time it rains.
Can I make up a mixture of cement, sand and water and drizzle it down into the larger cracks? Cover the smaller cracks with a layer of cement? I'm open to any suggestions, temporary or otherwise.
Old 01-19-19, 10:36 PM
Received 1,273 Upvotes on 1,213 Posts
Stuffing them with hydraulic cement might help.
Old 01-20-19, 02:29 AM
Do you think hydraulic cement would bond as well as regular patching cement?
Old 01-20-19, 02:45 AM
Received 850 Upvotes on 746 Posts
Most cement shrinks slightly as it dries, hydraulic cement expands slightly and dries faster than regular mortar.
Old 01-26-19, 05:06 PM
Thanks for reminding me that hydraulic cement expands. It makes more sense to use it for cracks as long as they aren't very wide. I've read that 1/2" deep is the optimal depth for using hydraulic cement, so I've been pouring some damp sand into the deeper cracks to get the max depth up to around 1/2". Does that sound like a good idea?
Old 01-27-19, 02:35 AM
I'd probably use multiple layers of hydraulic cement ..... but that isn't my area of expertise.
