Best wood to use for board form concrete walls
Old 03-06-19, 01:35 PM
X
What type of wood would you guys recommend for board form architectural concrete walls? I was think 1x4 pine, but I thought I'd check before I buy.
Old 03-07-19, 06:06 AM
P
Received 1,513 Votes on 1,360 Posts
It all depends on the texture you want visible in the concrete. I've seen planks, plywood and even silicone mats attached to the forms to create a pattern. With planks you need to pay attention to the board profile and any gaps between them. Some lumber has radiuses on corners which I think is too much texture but if you can get nice, straight square cornered planks then it can look good. Don't forget to coat the forms with a release agent.
