Water absorbment mats
Are there any type of thin layer sheeting or mats that could be placed under rubber floor tiles and over a concrete floor which might act as water/moisture absorbers?
any absorbent material will also have strong water - retention capacity - meaning that once it soaks up any moisture, it will hold it for a while.
Based on what you said - placing it under rubber tiles - which won't help with evaporation - you are asking for major mold issue.
Bad idea.
Bad idea.
joecaption voted this post useful.
I get what you're both saying. I guess I was looking at it from the standpoint of if I get any water seepage it might be a way of absorbing the moisture but obviously where would it go once it absorbed it. The concrete floor is usually dry plus I covered it with a masonry waterproofer so hopefully it won't be an issue and I'll just leave things as is. Thanks
So for the record I think I found what I'm looking for. I spoke to the company that I purchased the rubber tiles from. They sell various underlayments. One specifically is water resistant, mold resistant and acts as a vapor barrier. If I do ever get some moisture or small amount of water in this sounds like it would work.
