Using Driveway Pothole Patch for 900 sq. ft
Old 06-30-19, 09:10 AM
F
Hi Guys,
My driveway has a damaged area about 30' (L) x 3'(W). I found the pothole patch from Menards:
https://www.menards.com/main/paint/c...1174567&ipos=1
Can I use Driveway Pothole Patch to patch about 900 sq. ft ?
Thanks!
Old 06-30-19, 09:15 AM
Received 312 Votes on 278 Posts
I suppose you could but I wouldn't, cold patches are iffy and that is a lot bigger than a typical cold patch..
Old 06-30-19, 09:54 AM
Marq1's Avatar
Received 364 Votes on 340 Posts
Cold patch is intended to fill a void, it needs to be contained, it's not intended to replace asphalt!
Old 06-30-19, 02:13 PM
Tolyn Ironhand's Avatar
Received 207 Votes on 184 Posts
I have used that stuff after I cut up an asphalt driveway to make an underground repair. It goes in fine at first but will settle and not be flat over time.
Old 06-30-19, 07:19 PM
F
Thank you everyone! I will get the hot asphalt from a building material company instead.
Thanks again.
