Oil Stain on Driveway
Old 07-01-19, 10:41 AM
bobgrandi's Avatar
Hello all,
Is there a simple way to remove an oil stain from a driveway?
Any help would be greatly appreciated
Old 07-01-19, 10:46 AM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
Looks like blacktop, no way to remove, let it soak in and just seal it over next time you do the drive!
Old 07-01-19, 10:56 AM
Received 741 Upvotes on 647 Posts
You might try scrubbing it with TSP, that should make it less noticeable.
Old 07-01-19, 11:00 AM
bobgrandi's Avatar
At this moment less noticeable would be good. What is TSP?
Old 07-01-19, 11:01 AM
Tri Sodium Phosphate. sold at most hardware and paint stores
Old 07-01-19, 11:37 AM
bobgrandi's Avatar
Will give it a try. Thank you
Old 07-01-19, 11:44 AM
TSP is more/less a heavy duty detergent. Washing powder might work.
Old 07-02-19, 07:49 AM
B
Received 13 Upvotes on 9 Posts
Would liquid Dawn dish soap lift it, it works on ducks?
Old 07-02-19, 01:30 PM
Marq1's Avatar
You never confirmed it it was black top!
Black top is petroleum based so the oil is not an issue and removing will do more harm than good.
Just let it soak in and when you re coat the driveway it will not show up.
If it's cement, just get some gas and a old scrub brush and have at it.
