Dry Lock
Old 07-04-19, 03:36 PM
T
Dry Lock
Had a little bit of water coming in through a concrete block foundation in one location.
Installed french drain outside plus rain gutters.
Leaked stopped inside.
In heavy rain the interior wall gets damp only
if I dry lock this small area will that be a good idea.
Or should I leave it alone?
Thanks
Old 07-04-19, 04:34 PM
Norm201's Avatar
Received 291 Votes on 261 Posts
If it only gets damp it won't do any harm. As long as there is no pressure behind the dampness.
Old 07-05-19, 04:54 AM
Marq1's Avatar
Received 427 Votes on 398 Posts
Were you thinking inside or outside?
If inside it will just trap the water, you really want to repair the outside with a good waterproof membrane to keep it out of the block!
Old 07-05-19, 05:47 AM
P
Received 751 Votes on 690 Posts
Painting your basement wall with Dry Lock won't hurt. If the wall just gets damp it should do OK for at least several years but I have not seen it hold up long term when water is present.
Old 07-05-19, 06:16 AM
Received 361 Votes on 318 Posts
IMO drylok is more of an added insurance than an actual fix. It will stop minor leaks but then were does that water go? Sometimes it will just back up until there is enough pressure for it to find an exit. It's always best to stop the water on the exterior side! If all you have is dampness it should work ok.
