Cleaning surface of retaining wall
Old 08-01-19, 09:01 AM
L
Received 1 Upvote on 1 Post
I poured the retaining wall a few years ago but before installing the new screen door I want to set bricks along the top of the wall, should I clean the surface with a mild cleaning solution that would not affect the brick adhering to the top of the retaining wall.
Comments suggestions appreciated!!
Old 08-01-19, 09:23 AM
Received 786 Upvotes on 689 Posts
It doesn't look bad although it's never a bad idea to have it as clean as you can prior to laying the brick. Just make sure the cleaner is rinsed well.
Old 08-01-19, 09:47 AM
L
I thank you, considering using a very mild, perhaps 5% solution of muriatic acid, or TSP?
Old 08-01-19, 09:54 AM
P
Received 1,952 Upvotes on 1,748 Posts
You don't need muriatic acid since you are trying to remove things like dirt and mildew. A pressure washer would be my choice.
Old 08-01-19, 10:03 AM
L
Sounds a lot less labor-intensive than scrubbing, there are another 30 feet of retainer wall on the other side of the entrance, my pressure washer should have it prepped in proby less than a half-hour.
I thank you!
