Maintaining a steep asphalt driveway.
Hello All,
I have a short section of my driveway which is paved and fairly steep. I live in central NH, so we have winter, yep. I was told when I had it paved two years ago not to use any regular driveway sealer stuff on it as it would get too slick. It's slick enough as it as, believe me you. (It's a 105' rise over just under 600', a 20% grade average).
I'd think in this day & age there must be some kind of epoxy based product to use on asphalt to control cracking, seal seams, etc.
Any suggestions?
Any suggestions?
Never heard of any kind of epoxy coating but then again, the sealers for asphalt are meant to absorb into the base material not coat it with a non compatible material.
Only thing I can think of is to sprinkle some sand into the wet sealer but not coficent its going to last a long time!
My driveway is as steep or steeper in spots but mine is gravel.
I doubt adding sand on top of driveway sealer would last long. The sand added to porch paint generally wears off in short order with foot traffic .... and you'd have a 3-4 thousand lb car/truck going up/down it.
I agree blacktop sealer would likely make the asphalt slicker.
Amazing Driveway gap sealer/caulk that flows into cracks.
I have long used bags of play or beach sand mixed into water based driveway sealers. One gallon of sand per 5 gallon pail results in textured surface. Have also mixed it into paste consistency for repairing big cracks.
Have 200 feet of Belgium block curb that develop gaps with asphalt. Each year the ice widens gap.
Found an amazing caulking like sealer that flows into gaps and remains flexible when cured. While still liquid, use small paint brush to smooth out. Only drawback is available only in light gray
https://www.homedepot.com/p/Sikaflex...093828%7D%3Aqu
I would think you could treat your driveway like a road. Give is a tar and gravel treatment. That way you get a layer of tar to seal small cracks and a layer of gravel on top for traction. This is likely something you will need a professional contract for though.
