Do you wet ceramics before applying?
Old 08-23-19, 12:33 AM
kolias's Avatar
Received 7 Upvotes on 7 Posts
Does it help to wet the underside of ceramic floor tiles before setting them on the thinset?
Should I do the same with the thinset? (wet the concrete floor before applying the thinset)
Thanks
Old 08-23-19, 03:15 AM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
You only need that when it's really hot out to keep the moisture from being sucked out of the mortar and then I've only done it with brick work outside!
Old 08-23-19, 04:08 PM
Received 1,197 Upvotes on 1,152 Posts
Ummm....
No.
Old 08-24-19, 12:35 AM
kolias's Avatar
Guess it means no need to wet the ceramics/floor
Thanks to both
