how to repair my garage
Old 11-03-19, 04:54 PM
T
Hi, I hope I'm in right place
I have just bought a house and need to fix some things. I hope you can help with this crack above my garage.
Old 11-03-19, 05:13 PM
XSleeper's Avatar
Received 1,579 Likes on 1,415 Posts
Old 11-04-19, 05:49 AM
P
Received 1,628 Likes on 1,461 Posts
That's a decent sized crack. I would inspect the header/lintel above the garage door for signs of sagging.
Easiest would be to caulk the crack. I would probably use mortar though and fill it in as best as you can. The most proper way to repair it would be to dig out the mortar from the cracked joints and fully re-point (re-do) the mortar joints.
Old 11-04-19, 06:08 AM
T
"re do joints"... ok so you want me to take chisel and hammer and remove mortar which connects separated bricks and then fill that space with new mortar? Is there a... some kind of a gun to fill mortar in tight spaces? like a caulking gun but for mortar?
Old 11-04-19, 06:11 AM
As far as I know all you could do with a caulking gun is use a mortar caulk which could make it look decent but that type of repair is only cosmetic. IMO it wouldn't be that big of deal to chisel out some mortar and remortar with a small trowel, I suppose you could use a grout bag.
Old 11-04-19, 06:53 AM
Run a string or laser from one upper corner to the other to see if it is sagging in the center,
If yes it may be a major problem.
Old 11-04-19, 08:46 AM
T
ok I will check.
So what kind of major problem are we talking about? the roof is sagging or ceilling in garage needs to be rebuilt or reinforced?
Old 11-04-19, 09:23 AM
I would not obsess over it till you check it and see if it is sagging and how much is is sagging.
If it has been like this for years and not getting worse then it may have sagged shortly after construction and is now stable.
I just think it is better to be safe then sorry.
Old 11-04-19, 10:20 AM
T
I dont kbow the story. Previous owner wont talk to me.
Old 11-04-19, 10:52 AM
It might just be a settlement crack. I wouldn't be overly concerned unless the garage ceiling is sagging or the door doesn't fit properly.
Old 11-04-19, 11:14 AM
XSleeper's Avatar
The thing that concerns me is that the brick is supposed to be sitting on a steel lintel. That steel lintel should not let one brick slip down lower than the one right next to it. So in your photo, that dark black brick is lower than the one to its right. Even if the header has sagged, one brick shouldn't be lower than another on that bottom row because they should both be sitting right on the steel. They should not just be sitting on the wood trim. So I would tap around with a screwdriver underneath the bricks and see what you find. It's very unusual for the wood trim to protrude that far out, so it may have been added to hide something.
Old 11-05-19, 01:17 PM
T
How can I remove some photos? I cant add new ones.
Old 11-05-19, 03:09 PM
P
Look at the top of the forum section. There are instructions for posting pictures. The forum has a limit on the memory you can use but if you host your pictures on a photo hosting website there is no limit.
Old 11-05-19, 03:28 PM
C
If it were my garage I would chip out the old mortar and repoint the bricks. Google "repointing bricks" and you'll find several instructional videos.
If that solves the problem you're done. If it cracks again then you should look for the cause.
Old 11-05-19, 07:20 PM
T
the thing is. I just bought it. Previous owner didnt yell me that garage has a major problem so I can still take him to court and he will pay but if it nothing and putting new mortar would help then there is no need for court.
I looked everywhere. I cant see option to remove some of my photos. Ive reached the limit and cant add more.
Old 11-05-19, 07:50 PM
XSleeper's Avatar
Dont think we need more photos, it's pretty obvious that there is sagging. Bricks don't do that unless the header is sagging. The only way to know how much is with a stringline. The bricks seem to have dropped 3/8" on one side, which shouldn't be possible if they are sitting on the steel lintel... unless it is also bending as the header bends. Tuckpointing the brick is not a long term solution... it's more of a bandaid, or cosmetic solution. The brick above your house numbers is broken in half. Tuck pointing won't fix that.
This problem is only going to get worse over time unless it's fixed right. Drive through any neighborhood that was built 20-30 years ago and you will find similarly sagging garage door openings. Some guys just don't learn. The header needs to be larger. And LVL. (That garage opening would never fly nowadays, there also isn't enough framing on the sides of the garage doors to keep it square.)
You need to figure out like I said earlier if there is any steel under that brick or not. If there isn't, yeah you should be heading to court. Wood does not under any circumstances support brick. And unless that is just a shadow line on the top inch of that trim, that wood looks like it's being crushed under a load.
The way the brick is finished off on the right side of the garage door near the ground is a sure sign that it was amateur hour the day that work was done.
Old 11-06-19, 06:27 AM
T
I only wanted to show you these 2 photos.
https://www.dropbox.com/s/v0kjrxib0y...73001.jpg?dl=0
https://www.dropbox.com/s/nbms5ob70v...74316.jpg?dl=0
1) the wooden piece on the bottom of bricks is cracked in 2 spots : diagonally and straight). The steel plate should be there? or under?
2) I dont know if you can zoom in but there are 2 types of caulkings under bricks:
old white'ish.. used, torn...
and newer...ish clear not torn.
Why would you use 2 different caulkings?
Why should I call ? who should I find on yelp to inspect it and find how bad it is and the cost?
Old 11-06-19, 06:53 AM
Could be that the hosting site you are using is banned by this site or it's antivirus/antispam.
Perhaps a moderator can help you here, just give it a little time.
Old 11-06-19, 07:42 AM
XSleeper's Avatar
Yes, like I said, the wood is cracked because it is under load due to the sagging header and brick. It looks like the trim is covering (in front of) the steel that the brick sits on. If there is a gap above the wood you could tap / poke around above it to find the steel. Or just cut out and remove a piece of the trim. It will need to come out sooner or later anyway in order to be repaired.
As far as who to call, just call a mason in your area. If a carpenter needs to be involved, he will tell you. More than likely the header needs to be replaced. I wouldn't want the mason doing that unless he is proficient in both framing and masonry.
The only reason to call an inspector is if you need to use that as the legal basis to hire the repair work done.
He won't tell you more than we already have.
Old 11-06-19, 09:51 AM
T
Well, I need somebody proffesional to write a statement that problem like that doesnt show up after one night. With some huge luck mayve we can convince previous owner that this is not just cosmetic fix with adding mortar.
Im a truck driver now and believe me, I cant even enjoy this house. The last thing I want is to my wife calling me when Im far from home that garage has collapsed.
So ... call me stupid but I simply dont know. So should look just for "mason" in yelp or carpenter or general contractor? Can you tell me what kind of cost would it be to repair like it should be?
I would like to know if we can live with this issue for years or it may be next week when it will fall down on our car?
  #21
Old 11-06-19, 10:06 AM
P
Did you have a inspection performed before buying the house? If so you may have some recourse there.
How high is the ceiling in the garage? How does the sheetrock above the garage door look? Are there any cracks?
  #22
Old 11-06-19, 10:27 AM
T
Yes, I had inspection. I think this crack was on it but I didnt think it is serious. I didnt look on ceilling inside garage. But I know that top door panel is cracked and sagging...
Our inspector said I shouldnt worry much. I should hire bricklayer/mason and reinforce this area, patch crack. He also said that crack in bricks is most likely because of the ground movement, sagging. I have driveway cracked sideways 3-4 ft in front of garage and when it rains i have a lake instead of driveway.
  #23
Old 11-06-19, 06:44 PM
Received 3,183 Likes on 2,858 Posts
I resized your pictures for you. You are limited to 10mb so you can't post many 2-3mb pictures. You need to resize them to approx 600x600 and 100kb file size. You can use PAINT which is in most computers to do the resizing. If you hit your max or post large pics.... just PM to take care of them. You're now at 1.2mb of storage.
  #24
Old 11-07-19, 04:02 AM
B
I would suggest you hire a state licensed structural engineer to look at this. A licensed engineer is important if you think this may go to court and to get a person qualified to analyze the design of a structural beam and design a fix.
In the meantime, I don't think you have to worry about it actually falling down. Without getting real technical, it may be a bit underdesigned in allowable deflection, but I'm betting it's just fine in bending; masonry does not tolerate much deflection. There's also what called an arching effect in masonry that will help out.
  #25
Old 11-07-19, 06:52 AM
You have not said how much it has deflected down.
Since you knew about it when you bought the house I doubt that the original owner has any liability.
The inspector might have a liability issue but it would have to fall down first as he did note it but said it should be OK.
I am not an inspector but I disagree that it is due to shifting. If the sidewalls shift the header/lintel should still stay flat and not bow.
  #26
Old 11-07-19, 11:36 AM
T
Mortar will seal a crack fine but I typically use hydraulic cement to repair any crack for added strength.
It's been mentioned here but my primary concern is why it failed in the first place. That shouldn't move. Was the home professionally inspected prior to purchase? Any decent inspector should have caught that.
Given the location it certainly seems like the header is sagging. If you can confirm this is the case you would likely need to jack it back up and sister it to prevent future deflection.
Can you post a pic of the inside? t would be interesting to see how that span is supported.
  #27
Old 01-08-20, 09:47 AM
T
I'm sorry fir not responding, I had too many other problems.
So we moved in September 2019, our inspector told us this crack isnt scary and it is just because the house settles down but I would like second opinion so before I ask for contractor to check I wanted to ask you guys.
Here are photos from inside. In my opinion ceilling looks good but last top door panel is sagging. I dobt if it is because it is old and ugly or because motos is forcing it back and forward... lwt me kbow. Im adding more photos.
  #28
Old 01-08-20, 10:11 AM
P
The garage door sagging is a totally separate issue, and is somewhat common. There are stiffener strips that can be bolted to the back of the door if it bothers you. It looks like you already have one installed about half way up. When I built my house I wanted higher than required wind resistance so I have them on all my panels.
  #29
Old 01-08-20, 02:44 PM
T
I assumed the inside of the garage would not be finished and the header would be visible.
IMO, while a new house will certainly settle a bit, you should not have cracks like that in your mortar. It probably wonít open up any more but if it were my house Iíd open the wall to inspect the header over that door. I would jack and sister it. This will close up the gap as well as correct the sag.
Iíve seen doors in new home builds with no header at all. Just rough framing. Iíve seen some really poor new construction.... especially with things like this where they know the final product will be concealed.
  #30
Old 05-11-20, 11:59 AM
T
I finally called a friend of a friend who is bricklayer. He checked it, grinded old concrete from between the bricks and filled new. It looks much better. He said no to worry to much, "it won't collapse". He said "the beam" is broken and we can live like this for few more years but when we are ready the cost just for material will be around $2500 because he will have to remove and rebuild(with new bricks) whole front of garage.
