Fix paving stones
Old 12-29-19, 06:46 AM
I
Received 1 Upvote on 1 Post
Fix paving stones
I have a walkway made with paving stones that are over a 1w inch square. It is sunk below grade I want to raise it up to just above grade but low enough I can mow over it. I have never laid pavers before what would be my best plan of action
Old 12-29-19, 10:10 AM
Received 266 Upvotes on 238 Posts
First thing to do is to Google "how to lay paving stones" and watch a couple videos etc.
You did not say how old this walkway is so perhaps it was never packed properly and that is why it sank.
If this is the case then you should pack it before reinstalling your pavers.
Old 12-29-19, 10:14 AM
Received 754 Upvotes on 659 Posts
Has the whole thing sunk or just specific areas?
Old 12-29-19, 10:17 AM
I
The whole thing. It would be less than 20 years old. What would be the best way to pack it.
Old 12-29-19, 10:24 AM
It's already packed I'd level it up with stone dust or fine gravel.
Old 12-29-19, 10:40 AM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
Not uncommon for them to settle over time, since it's been that long you can assume the foundation is solid and this is just a fine tuning needed to bring them up to level.
Assuming you need an inch, you can buy lengths of 1" dia conduit, lay a pair along the path, fill path with slag sand and using the conduits as guides to screed the sand out, pull the conduit up, fill in the grooves and relay the stones.
When done you compact the stones into the sand with a plate compactor, fill gaps with polymeric sand, compact again, and your good for another 20 years.
Its a fair amount of work!
Old 12-29-19, 11:22 AM
I
Whit kind of sand/gravel should I out under them. And I'll use the paver locking sand between them.
Old 12-29-19, 03:31 PM
Marq1's Avatar
Thought I had that, slag sand works good!
Old 12-29-19, 05:01 PM
I
I've never heard of slag sand.
Old 12-30-19, 08:05 AM
I
I can't seem to find slag sand locally. Soni just need a paver sand to put under them
Old 12-30-19, 10:03 AM
Marq1's Avatar
Might be a local name, whatever is used as the setting sand in your area will work!
