Over the years, I have noticed small holes in Concrete Garage floor.
I had painted it couple of times but paint and top layer has been eroded as I park my vehicle inside - Canadian winter (so salt and snow) and summer.
Is their any easy solution to fix this? As I am not sure how handy I will be with the overlay process.
Any suggestions to how furnish a top layer which is smooth and does not erode easily.
Since you have multiple layers of paint on the floor most things you can do are going to require serious work. The first step for almost anything is to provide a clean surface. Usually that is done by grinding. I would consider hiring this done but you can check tool rental stores for a grinder but it's a messy, sorta tedious job as you are literally grinding away the top layer of concrete.
That is normal wear to concrete, salt is not kind.
Epoxy flooring is the most widely used, had mine done about 6 years ago. Has held up well with the exception that it will fade so have had to learn to keep the doors closed.
As noted it's all about a virgin surface to everything would have to be ground down to remove all the spalling surface and paint, it's a mess!
I've seen DIY kits, not a lot better than paint, all the cracks and joints require special fillers or they are the first to crack. Any moisture that comes up will simply push up the material so again it's all in the prep.
Thanks for your feedback and sharing the pic of your garage..
I think - it looks like that I also have to get the epoxy floor done.. The reason I wanted to avoid that is because I have couple of heavy cabinets, shelves besides lawnmower and snow blower in my garage - no other place to put them easily or temporarily.
I was hoping to find if I could put something on top to stop the erosion and smooth it out but looks unlikely.
Thanks for taking the time to reply.. Have a nice day!!
Hello!
I want to close up a basement window in our cinderblock foundation. I'm trying to not rent a concrete saw if possible. The height of the opening in the basement wall is 19". I haven't taken the window out yet to see if they built up the blocks an inch with concrete to reduce a 20" opening to 19" for the window (it's parged over), but it doesn't seem like it.
What is my best option for closing the 19"? I want to stick with concrete blocks and not bricks or anything else. How do I get to 19 inches when blocks are 8" or 4" tall?
Thanks guys!
Read More
I have a patio area that is a concrete slab with old reclaimed Chicago clay bricks. The bricks are set on thick set mortar with mortar joints.
There is an area with 8 bricks along the edge that I removed because two of the bricks popped loose. In trying to clean up the grout joints surrounding the two bricks, six other bricks came loose from the chiseling.
It appears the original thick set mortar at the bottom of the bricks are very solid and won't come out easy. If I start to chisel out the mortar to get more depth to set the bricks with a new layer of mortar I may end up popping off even more adjacent bricks. I have heard that there are adhesives that I can use to reattach the bricks and may be stronger than setting it on a new bed of mortar if the original mortar is solidly bonded to the concrete slab. Is this true? If so, any recommendation of what kind of adhesive?Read More
