How to repair this foundation corner?
Old 09-08-23, 03:45 PM
My main question is: can I keep the block circled in green?
Option 1: remove the block circled in green and rebuild the corner, please tell me how, shall insert some iron bar inside, etc.
Option 2: remove all the lose concrete as I am doing now, and use concrete to bond the block in green back to the original. What type of concrete shall I use?
Thank you!
Old 09-09-23, 01:37 AM
Received 1,273 Upvotes on 1,213 Posts
How about some additional pictures from further back?
Old 09-09-23, 04:37 AM
B
Received 308 Upvotes on 273 Posts
Those cracks suggest a structural problem like a bad footing or foundation. DIY repair not likely due to equipment and experience needed.
Old 09-09-23, 04:42 AM
I wanted the pics for more info but I think Bob is likely correct.
Do you know why this is happening?
Old 09-09-23, 01:45 PM
maarkr's Avatar
Received 23 Upvotes on 20 Posts
y, what state are you in? is this related to a drainage issue where you have lost of water around the foundation?
Old 09-10-23, 04:29 PM
T
Received 52 Upvotes on 44 Posts
Did you recently, perhaps to show the area in question, remove the elbow from the downspout? That is some serious damage. I can imagine a couple ways to “fix” it but they are not structural and will only make it look better.There are people who know more than I do who can help.
