what would YOU masonry guys do right here?!?
Old 03-03-24, 07:24 AM
N
what would you guys familiar with masonry do right here? i want to make it square and straight for a door? should i jus get rid of as mush loose material as possible? then put brick where it would fit and make it straight with mortar? what would do with the top
Old 03-03-24, 09:50 AM
Received 850 Upvotes on 746 Posts
Looks a little narrow, does it need to be widened out any for your door?
Old 03-03-24, 10:10 AM
N
just alittle about 6inch
Old 03-03-24, 10:44 AM
wouldn't widening it out 6" take care of all the jagged brick?
Old 03-04-24, 05:52 AM
P
Received 2,217 Upvotes on 1,979 Posts
I would saw cut where you need the opening.
Old 03-04-24, 04:32 PM
Received 4,046 Upvotes on 3,630 Posts
I agree with saw cutting and would recommend only cutting the left side as seen in the picture.
The right side looks fairly square and stable.
Pay mind to the lintel between the top of the brick and framing.
It looks like it's holding up the patched framing.
