Go Back  DoItYourself.com Community Forums > Recreational Outdoor Activities > Camping, Hiking, Backpacking, Climbing, RVing
Reload this Page >
Can a power station be charged for the required 36 hrs. using a gas generator
Old 08-07-19, 09:20 AM
F
I have just purchased a Master Craft 1000 amp/500 running watts power station, and it has a 36 hour initial charge time.
My question is: is it possible to charge it the 36 hours using a Sportsman 1000 Watt/800 running watts Inverter gas generator?
The generator can run maybe 8 hours then I would let it cool for about an hour, then start the charging again. Is this possible or does it definitely need 36 hours of continuous charging, no interuptions?
Old 08-07-19, 10:12 AM
P
Received 2,114 Upvotes on 1,893 Posts
Almost any device can pause during the charging cycle.
Why are you charging for 8 hours then stopping? Do the instructions for the master Craft tell you to do that? Almost anything is going to be up to full temperature in the first hour so I don't know what benefit cooling after 8 hours would offer.
Old 08-07-19, 08:33 PM
Received 3,897 Upvotes on 3,494 Posts
That 36 hour charge may be for just the first time that pack is charged.
I couldn't find any helpful online info for that unit.
