Coping and 120 degree angle
Old 04-12-16, 04:39 AM
B
New to coping. I read that you first cut with a power saw after measuring an angle.What angle do you use if the measured angle is over 90 degrees. The angle is about 120-130 degrees. This will be crown molding for ceiling.Don't remember my math and angles.
Old 04-12-16, 05:42 AM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
You can start with a 45. Follow the front edge of the cut as you cope. You just need to back cut it more for a 120. Same as coping a 90 but you back cut it an add'l 30 degrees. A grinder with a flap sanding disk is practically a must have for coping crown.
Old 04-12-16, 06:03 AM
W
Received 51 Votes on 46 Posts
Angle
120 / 2 = 60. Use half the obtuse angle.
Old 04-12-16, 06:14 AM
XSleeper's Avatar
I highly doubt he has a miter saw that can make a 60 degree miter. As I mentioned, its not the miter you make that matters... its the amount of wood you remove when coping. Cutting a miter just gives you a line to follow on the front of the profile.
Old 04-12-16, 09:07 AM
W
Profile
Would not the profile change as the angle changes?
