how to remove chair rails that flow into the window
Old 08-07-16, 12:35 PM
C
Size:  23.4 KB Hello,
How do you remove chair rails that flow in to the window. Please see attached picture.
I want to remove the part of the chair rail that is inside the in window because the blinds do not have enough room to close.
I just bought this house a few months ago and starting doing little DIY projects around the house. I am new to this site and to working with my hands .I got a ton of things to get done before the new baby arrives next week.
Thanks in advance,
Old 08-07-16, 12:38 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Where is the picture? I'm guessing that if you say the chair rail turns the corner and goes inside the jamb of the window, thereby reducing it's width, that you would need you cut it and return it to the wall just short of that outside corner.
Edit: there it is.... yeah, you would stop the moulding short... so it would be like moving the miter back 1/2" or so... and the return would return to the wall... not to the window. So the return portion would just be a tiny triangle.
Old 08-07-16, 12:58 PM
C
Thank you!
So I just need to cut enough off to add the returner. What is the best tool to cut the chair rail?
Attached is after I removed the window portion of the chair rail.... looks like they painted this room orange at one time...
Old 08-07-16, 02:23 PM
Received 128 Upvotes on 113 Posts
There is no way to cut that beaded molding leaving it in place.
Need to cut the paint and caulking lines to remove it.
It's cut with compound mitre saw.
In a pinch a cheap mitre box will work.
The return will need to be glued on, not nailed.
Old 08-07-16, 04:36 PM
XSleeper's Avatar
Well, a pro would do as joe says, put it on a miter saw, cut a new 45 on the remaining piece.. cut a small triangular return out of the piece you removed, then glue that onto the end.
But assuming you don't have any of those tools you might just want to take a hand saw and cut that moulding off square... flush with the corner. Then clean the cut up with some sandpaper. Its not the way a pro would do it but it would still look ok once painted up.
Old 08-08-16, 04:38 AM
Received 800 Upvotes on 703 Posts
I agree it would be easiest to just cut it flush and touch up the paint. Another easy option might be to replace the piece you took off but cut it shorter so the blind has room to clear it.
Old 08-08-16, 04:59 AM
If you have to flush cut it place use an oscillating multi tool with a plunge blade. Hold a guide along the cut line so the blade cuts a straight line.
