Baseboard trim going down stairs
Old 01-01-17, 02:41 PM
Hello. I am just wondering what the best way to cut/end/terminate the piece of trim in the attached image. I need to use trim on the stairs due to the floating wall. Thanks
Old 01-01-17, 02:44 PM
Cut the end the same angle as the corner then nip or bevel the edge of the baseboard.
Old 01-01-17, 02:58 PM
chandler's Avatar
I guess Mark is talking the same thing, but measure the angle from the molding to vertical. Divide it in two and make a return from the molding, again, cutting the return piece at the angle of the stairs.
Old 01-01-17, 03:25 PM
Thank you for the replies
Old 01-02-17, 03:58 AM
Actually I wasn't thinking about using a return but that does make for a nicer look
