Door jamb hollow
Door jamb hollow
The door jamb is hollow behind the lower screw. I wanna secure the strike plate, this is an old home, what can I do?
You can fill the hole with Bondo automotive fill compound (separate compound and hardener) or Durham's Rock Hard Water Putty.
The important thing is to fill the hole completely and scrape it level. Both the Bondo and Water Putty are hard to sand.
It's also important to drill your new hole accurately in the center. Use a center punch or a nail to mark the center and to keep the drill bit from walking.
Are you joking. I thought the stuff u recommend is for filling holes in metal only, not wood
I don't joke about holes in wood, I take them seriously
Bondo is perfect for filling holes in wood. I used to reface cabinets a lot and Bondo was pretty much mandatory to fill holes and square off rounded off edges.
