Attach Handrail to Plaster Wall
I need to attach a lightweight wood hand rail to a plaster wall using 2-3 lightweight metal brackets. Given the wall is plaster lath, what is the best type of bolt/screw to use? Each bracket has screws (two small ones at top and larger one at bottom), and I thought a toggle might be best to use for the larger bottom screw.
Any suggestions are very welcome!
Best thing to do on any handrail bracket is to find the studs... And that's where the brackets have to go. You can usually do that on plaster with a magnetic stud finder because the lathe will be nailed to the studs. Anchoring to lathe only is just asking for trouble. It will last a while but it has the potential to bust out a lot of plaster when someone yanks the lathe off the wall.
I agree, not having the rail secured to a stud is a safety hazard! If you have trouble finding the studs with a stud finder you can drill 1/8" holes where you think the stud might be .... until you find them. The little holes are easy to fill and make disappear.
