Looking for conceleaed hinges ideas for picture frame
Old 02-24-18, 12:40 PM
D
Received 1 Vote on 1 Post
I am looking for ideas on what hinges to get to mount a picture frame onto a wall, allowing me to "open" the frame as a hidden area cover.
Standard hinges woudl be visible...
Old 02-24-18, 01:14 PM
Received 77 Votes on 72 Posts
Old 02-24-18, 01:57 PM
D
I am not sure whether a plain hinge woudl work. If the picture frame clears the wall the hinge woudl need to be installed on the side, sticking out slightly? Would be visible when looking form the side.
Old 02-24-18, 02:07 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Here is a page of Blum hinges. Should find what you want here. Blum are one of the best himge.
https://www.handlesets.com/blum/c753...hoCjTkQAvD_BwE
Old 02-24-18, 02:24 PM
D
that might work - if the picture frame allows for drilling a hole for the cup.
Old 02-24-18, 03:40 PM
XSleeper's Avatar
Received 676 Votes on 625 Posts
I would imagine you would need to build a box or jamb that would be recessed into the wall. You would then use a plate mount (mounted to the side of the jamb) full overlay 35mm hinge... like you say, as long as the frame is 3/4" -thick, because the cup bore will be 1/2" deep.
Old 02-24-18, 05:58 PM
Handyone's Avatar
Here's a box designed to hide guns. The hinges would not be visible.
https://www.sportsmansguide.com/prod...ampaign=CI#TBD
A medicine cabinet might work also, replace the mirrored door with a picture frame.
Either way the interior box will need to stick out from the wall a little but I don't think it will be noticed.
You could also add a child lock similar to this, There is no way to open the door unless you know where the magnet is located:
https://www.rev-a-shelf.com/p-192-ca...cessories.aspx
