New wall and Crown Molding
Received 0 Votes
I'm dividing a large room in 2 but there is baseboard and crown molding around the entire room. I can't think of an easy way to miter the corners of the new and old moldings without having to remove all the moldings already installed that will intersect with the new wall.. Ideas?
Thanks
Thanks
The existing one gets a square cut. The new one that lays over it gets COPED. Watch a video on coping if you don't know how. It gets cut at a 45 like a miter but then you use a coping saw or jigsaw to remove the wood that has been crosscut, leaving only the outline of the profile.
The profiles need to match exactly for a cope to look the best. When you do it right it looks just like a miter.
