Laminate cabinet door edges are chipped
Old 07-25-18, 11:07 PM
P
The hard laminate covers are easy to clean and I like them. But the edges are chipped from years of use. Is there a way to restore the doors? Can I buy laminates and glue them over existing laminate covers? Color is light beige.
Thank you.
PS: Actually, my preference is to pay a pro to do the restoration for me.
Old 07-26-18, 03:12 AM
Received 312 Votes on 278 Posts
Since you prefer not to diy, I'd suggest getting estimates both for re laminating and replacement doors.
Hard for us to advise further without seeing what you have.
Old 07-26-18, 05:38 AM
P
Thank you for the reply. This is what the door bottom looks like. The photo covers about 6 inches of door width. Top is door. Cabinet is hung on the wall. Just this door is chipped this bad. All other doors are either fine or have one nick about 1/8" at the edge.
Old 07-26-18, 06:27 AM
I'd replace those doors. ,,,,,,,,,,,,,,,,,,,
Old 07-26-18, 01:38 PM
P
Where can I get replacement doors? I talked to Lowes, but they discouraged getting just the doors.
Old 07-26-18, 02:14 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Here is a page to look at.
https://www.google.com/search?q=repl...hrome&ie=UTF-8
Or type replacement cabinet doors in google it will give local places
Old 07-26-18, 02:16 PM
XSleeper's Avatar
Received 665 Votes on 615 Posts
Cant tell anything about the style of door from the closeup. Need a picture of the whole door.
Old 07-26-18, 03:17 PM
P
2 photos including side view of the door, open position. Door bottom makes 60 degree angle. The same laminate is used for cabinet box front, door front, both door sides, door top, and door bottom.
Old 07-26-18, 03:33 PM
XSleeper's Avatar
That helps. I think about any carpenter could make those for you.
Old 07-26-18, 06:46 PM
P
Thank you. I assume you mentioned carpenter because it will cost less to have one made by a carpenter than a cabinet maker. What if the carpenter wants to glue a laminate on existing door? Should I let him? Or should I insist on having a new one made from scratch? I am asking this because you suggested replacing over re-laminating.
Old 07-26-18, 07:39 PM
XSleeper's Avatar
Laminate does not stick to laminate very well because it is so slick. Also, it would be a weak bond where the chipping is occurring, so it could easily come loose.
also keep in mind there are many different "whites" and also different sheens on laminates, so there is the real possibility that your door will stand out as different from the others no matter how you look at it.
Bring home laminate samples and see how they look. The 2 big brands are Formica and WilsonArt.
Old 07-28-18, 08:20 PM
P
Sorry for late reply. I got busy with painting the house. Thank you for the notes.
