DIY level
Old 01-20-19, 10:31 AM
Q
Received 1 Upvote on 1 Post
DIY level
Can I use a 2' level and attach it to a 6' piece of flat wood to use as a 6' level? Will it work well?
Old 01-20-19, 10:38 AM
Received 871 Upvotes on 762 Posts
A lot depends on how straight the wood is. I've used shorter levels on longer boards and while it works it might not be as accurate as it would be if you had the longer level.
Old 01-20-19, 10:42 AM
A
Received 73 Upvotes on 66 Posts
Level is level, simply a matter of reference between two or more points, so yes, it will work. But the trick here is how "flat" is your "flat board", so although I almost always do it anyway simply as a matter of habit, this is definitely a case where you would want to flip your level around and check it both ways to be sure.
