Fixing door panel - detached
Old 01-27-19, 11:07 AM
Hello,
I am trying to figure out see the best way to fix this door bottom that seems to have become detached
from the frame ... see picture
would a little carpenter glue and weight on it do the trick ?
thx !
Old 01-27-19, 12:33 PM
P
Received 895 Votes on 825 Posts
I remove the door from the hinges. Then I gently insert something to hold the veneer away from the door's frame so you have room to work. Then I smear wood glue on the door's frame. Pull out your spacer and clamp or stack weights on to hold the veneer in place until the glue dries.
Old 01-27-19, 02:07 PM
Received 404 Votes on 360 Posts
I'd do the same but add some brads to hold it tight. Putty and paint will hide the brad heads.
Old 01-28-19, 10:45 AM
great thx ... will try that. Just wondering if the wood glue will hold it together
Old 01-28-19, 11:20 AM
Either wood glue or liquid nail will work.
Old 01-30-19, 07:46 AM
thank you all will report back
Old 01-30-19, 07:52 AM
XSleeper's Avatar
Received 937 Votes on 855 Posts
When you take it off the hinges and glue it, you will want to use a 1x4 (on edge) and some quick clamps to keep pressure on the wood glue. Wipe off any wood glue that squeezes out with a wet cloth. Keep it clamped for a couple hours. Should be good to go after that.
