Joist Direction
Joist Direction
Took out an old spiral staircase and not sure which way to run the floor joists to fill the hole. Any advice much appreciated.
Can't tell anything from that pic. They generally should run the same way as the other floor joists.
They are nailed to the joist running left to right and run on out to an outside wall. Behind the camera is a header nailed to joists that run parallel to the ones on the left and right and they run on out to the same outside wall as well.
