Hinge detached from back of mirrored door on medicine cabinet
Hello,
I have a medicine cabinet in my bathroom. The cabinet has two doors on the front that open to each side from the middle. The front of the doors is a mirror but the back of the doors is a smooth grey surface. On the inside of the cabinet, each door has a metal hinge on the top and bottom. The hinges are glued to the back of the doors.
One of the hinges has become detached from the back of the door. What type of glue should be used to reattach the hinge to the back of the cabinet door?
Thank you.
Thank you.
You could get the same type they sell in hardware stores to affix rear view mirrors to car windshields.
A small amount of 100% silicone would probably also work but you would have to give it time to set up.
