How high should the top of a mantel be?
Old 03-05-19, 04:07 PM
K
Received 1 Upvote on 1 Post
I have check online and seen several different suggestions so I thought I would ask you guys what your opinion is.
The hearth is at floor level. What level would you suggest is the best height?
A little additional info is that this is in a small 1 bedroom cabin. The wall that it is on is 8' wide and is about 80" high.
Thanks
Old 03-05-19, 04:13 PM
P
Received 2,122 Upvotes on 1,899 Posts
Most often I think it's dictated by the clearance above the firebox opening. Once you've met the minimum height requirement you can go as high as you like.
Old 03-05-19, 04:17 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
There is no standard height since every fireplace size and height is different. The "minimum height" for the bottom edge of a mantel that is made of a combustible material is 12" above the fireplace opening, See R1001.11 exception 4.
That being said, 60" is what might be most pleasing for the majority of them... since that's just below chin high... any higher seems high, any lower seems low.
