Building staircase & podium (for theatre)
Old 04-17-19, 01:06 AM
V
Hi there!
For our (very small) school theatre, I'd like to build some curved staircase with podium. I'm aiming at something like that:
https://static1.squarespace.com/stat...G?format=1000w oder https://i.pinimg.com/originals/50/d2...3564ae089f.jpg
It doesn't have to look exactly like this.
The overall height (podium height) should be around 150cm [5 feet], one curved staircase (left or right) is sufficient.
Do you have any ideas and hints how to build something like that easily, with leight materials, which materials and components could you recommend?
Kind regards
Last edited by the_tow_guy; 04-17-19 at 04:27 AM. Reason: Clarified measurement for USA
Old 04-17-19, 04:31 AM
the_tow_guy's Avatar
Received 250 Upvotes on 202 Posts
Is this going to be a fixed structure or something that will require moving? If it requires moving, you would probably want to make it more of a modular design, i.e. several pieces that could be connected, but able to come apart to move. Here in the US I would probably recommend plain pine lumber; plentiful, fairly cheap, and lighter than some other species, although it is still likely to be fairly heavy. Not sure what lumber resources you have in your area.
