Caulk or not to caulk?
I am building some mudroom lockers. I love how they are turning out, but now I am starting to paint. And the couple gaps in the trim are kind of bugging me. I always sand and fill seams between coats, but not sure what to do about the gaps between pieces. I attached a picture of what I mean. (This is after I just sanded first coat of primer.) But would you typically caulk that? I am nervous because most of the stuff I have caulked like this (Old door panels, my crown moulding, my trim around my windows) that was all painted white, ended up cracking anyways and almost looked worse the if I would have just left the gaps... They aren't huge by any means, but still would like them to look more flush. I have used DAP caulk that somewhat yellowed and cracked and also have used Big Stretch caulk... So do I just leave it any hope the paint helps fill it in? Or attempt to caulk? Or I am open to any suggestions from the pros.
Thanks!
Thanks!
Gee, those gaps seem so minor I would not do anything to them. By leaving them you won't have any yellowing with age or any cracking. And the next time you paint you don't need to worry about removing any caulking that might need replacing.
