how do you make a straight but uneven cut on a board?
Old 12-30-19, 01:39 PM
G
this feels very basic like I should know it, but frankly I don't! I need a length of 5/4" pine that is 15/16" on one end and 1/2" on the other, so the strip will taper. In other words, the two opposite edges of the board need to be straight, but they are not parallel. Does that make sense? thanks as always
Old 12-30-19, 01:45 PM
B
Received 42 Votes on 38 Posts
What do you have for tools, specifically a saw or two?
Bud
Old 12-30-19, 01:52 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Best way is with a table saw. You tack a guide board onto your piece so that you can just set the fence and rip it.
Old 12-30-19, 03:12 PM
the_tow_guy's Avatar
Received 146 Votes on 114 Posts
This is a fancy version of Sleeper's suggestion:
https://www.woodworkersjournal.com/t...per-jig-plans/
Old 12-31-19, 12:39 AM
Marq1's Avatar
Received 950 Votes on 862 Posts
Length of the cut also needs to be considered.
I dont think you can get a taper along a 8' board with that saw fixture so a straight edge and circular saw would be an option!
Old 12-31-19, 04:48 AM
Did I miss something? 8 feet? Point well-taken, though. The taper jig would be for shorter work.
Old 12-31-19, 06:34 AM
Marq1's Avatar
It wasn't specified by the OP!
Old 12-31-19, 08:38 AM
G
wow all great thx taking it all in!
Old 12-31-19, 05:23 PM
T
Received 4 Votes on 4 Posts
Is this for decking? If so I have done this by just marking with a chalkline and using a circular saw free hand. If this is for a finishing piece or cabinetry on the inside, then using a clamped fence with either a circular or table saw would be more perfect.
