They painted my bathtub
The genius I bought my house from thought it would be a good idea to paint the bathtub. You can imagine what water soluable paint does over time as the kids take showers. Now I have a big mess. What is the easiest way to remove this paint? Would post pics, but not seeing a way to.
Welcome to the forums Josh!
Just to be clear they used latex paint and not a tub/tile paint? Denatured alcohol will dissolve latex paint or a paint stripper could be used but I don't know how either would affect the plumbing.
http://www.doityourself.com/forum/el...-pictures.html
Have never used alcohol or heard that it will strip latex paint but goo-gone is a citrus based material that will clean/strip latex paint.
I would just work an area at a time and try not to get too much down the drain.
Paint remover/brush cleaner. Sold in the same aisle as paint thinner. There must be a reason they painted it. (Probably was unbelievably dirty and they thought it was an improvement.. still a bad idea).
I'm with XSleeper. There must be a reason they painted the tub. It's something that's done to make a bad tub look good for selling. I assume after you get the paint off you'll find that the tub underneath is either a crazy color or has bad scratches or the finish is worn through. Whatever the cause you probably will need to replace the tub or consider a professional refinishing.
Doesn't look like it will be too difficult to remove the latex paint. Might want to tape up the drain to prevent the peelings from going down the drain.
I don't use strippers often and generally ask the folks at the paint store which one would be best for the job at hand. I'm not sure if one of the least caustic strippers or denatured alcohol along with a scotchbrite pad would be best.
When we bought our house, about a week later we realized the previous owners had painted our tub with latex. Just keep having daily showers or baths with a drain strainer. It honestly won't take long to have the thing strip itself.
I'd also second the motion of starting to get ready to replace it.
