Lime-away with the cloth problem
Old 04-27-18, 09:26 AM
I already used limeaway with the cloth then I put the lime-away with the cloth on the kitchen counter. I went out for 4 hours and went home. I saw the cloth spilling it on my counter. How do I remove it?
Old 04-27-18, 10:20 AM
XSleeper's Avatar
Received 1,570 Likes on 1,408 Posts
Looks permanent to me..... maybe lacquer thinner on a cotton swab. Doubt it will help.
Is that laminate or real wood?
Old 04-27-18, 11:09 AM
Can I put the cloth and use the iron to remove?
Old 04-27-18, 11:32 AM
Shadeladie's Avatar
Super Moderator
You sure it didn't remove the finish or color? I'm thinking it works like an acid when sitting too long.
Old 04-27-18, 11:38 AM
The safety data sheet for Lime-Away says it's corrosive, so I would bet that it took the finish/color off of the counter top. I'm afraid I, too, believe it is permanent.
Old 04-27-18, 02:42 PM
Can I use the wood stain to cover it again?
Old 04-27-18, 02:44 PM
Is the counter top real wood? It almost looks like a wood-look laminate.
Old 04-27-18, 02:52 PM
If it's real wood it can be refinished but if it's a laminate it can't. If replacement isn't in the cards it might be a good idea to figure out a nice way to set something over it to hide it.
If it's laminate, I'm not sure there is anything you can do aside from replacing the countertop. You could always tile the countertops, but for the amount of work and cost of doing so (and maintenance), you might as well just replace the countertop.
Old 04-28-18, 09:06 AM
2
If it is laminate you could rout out an area and set in some ceramic tiles either as decorative cover-up or for use as a hot pad if it is near the stove.
Old 05-04-18, 05:41 PM
Spilled lime away spray on my Laminate Wood Look Countertop Kitchen
I spilled lime away spray on my Laminate Wood Kitchen Counter top. I saw the blue spots. Can I use the electric sandpaper to remove the blue spots or somebody else before staining it again
Old 05-04-18, 05:59 PM
XSleeper's Avatar
You still haven't answered our original question.
Is this laminate or is it real wood?
Old 05-04-18, 06:07 PM
Shadeladie's Avatar
Super Moderator
He did. He said it's laminate.
Old 05-04-18, 06:11 PM
XSleeper's Avatar
All sandpaper will do is scratch up the surface. And laminate does not accept stain.
