Is there a way to clean this fixture lens?
This is the cover for the light in the standing shower. If there is no way to clean this, does anyone know where I can find a replacement? It's an AquaGlass shower.
It can be cleaned but the big problem is the corrosion. The trim ring could be painted or re-chromed if you can't find a replacement.
Use some type of copper, silver, stainless steel cleaner. Then use a clear coat spray on protector. It won't last forever, but it will protect it from moisture. You may need to re-apply in about a year.
Found nothing like it at Aqua Glass. If it's part of the shower system..... try contacting them.
I couldn't find anyone currently selling a 3 hole replacement lens.
I had the same style and used sandpaper to clean it up. Then I sprayed on white paint. Super easy and it has lasted more than 5 years. There are as many color options as there are spray paint cans in the store. You can even go with a metal look spray.
- Peter
- Peter
