Adequately dried basement carpet?
Old 03-15-19, 05:32 PM
D
We have some cheap carpet down in a basement bedroom (previous owner installed it, I’m fairly certain there isn’t even padding installed between the underfloor and the carpet, or if there is, it isn’t much).
Today, about half a gallon is cream bucket worth of water (maybe less) got spilled onto the carpet in about a 1ft by 1ft area, at the absolute most.I soaked up as much as I could with bath towels, tried using the wet/dry shop vac (which didn’t seem to pull in any water at all).
I’m highly allergic to mold, so I’d definitely like to stop this before it can become a problem, but I also recognize that it’s a really small patch of the carpeting and could be worrying over nothing.
Is there anything else I should do to try to dry this spot to avoid mold? (Figuring out how to lay a stand fan on its side to help dry it out or something)
Old 03-15-19, 05:34 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
A box fan, keeping air moving on it is probably all that is needed.
Old 03-16-19, 12:43 AM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
A small water spill itself wont cause mold, mold is possible in constently damp, wet environments!
