Magic Marker stains on flat painted walls
Old 11-18-19, 05:34 PM
K
What do you use to remove magic marker and crayon on flat painted walls?
Old 11-18-19, 05:41 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Magic marker is usually permanent. Denatured alcohol will usually remove crayon. Even if you remove it, flat paint will need to be repainted / touched up.
Old 11-18-19, 05:45 PM
Received 94 Votes on 83 Posts
Just about any scrubbing of flat paint will burnish it to a sheen and most solvents which can affect the marker will affect the wall. Alcohol is typically a good solvent for ink while mineral spirits might be a better choice for the crayon but you could try the alcohol as well. Regardless, I would be ready with an oil based sealing primer and expect to be painting.
Old 11-19-19, 04:21 AM
Received 319 Votes on 283 Posts
Magic marker ink is some of the hardest ink to seal. I'd try washing off what I could and then seal the ink with pigmented shellac [BIN] some times it takes 2 coats of BIN.
