Deleting duplicate video and image files
I backed up the micro SD card from my cell phone this afternoon and clicked okay to merge folders with duplicate name (e.g. MEDIA, DCIM, etc). However, I also inadvertently clicked "copy and keep both files". So now I have hundreds if not thousands of duplicate files (one with the original name and one with a "(2)" at the end). Is there a simple way to delete all of these duplicate files? I started to delete them one by one but it was taking extremely long a time. I found a couple software tools online, but two of them didn't work and the third costs $59.95. I just need the program one time though.
Stickshift has the right idea. Use the wildcard. Open a command prompt. Type the drive letter followed by a :
Press enter.
Then use the cd command to get to the correct directory. For example: cd dcim Press enter. Then run:
or whatever
Press enter.
or whatever
This one is for free and should get you where you need:
Download Duplicate Cleaner
If you are not computer savy, I would avoid using command prompt with DEL and wildcard command. It will lead you to a new problem if you delete the wrong files, which is recovery. And from what I recall, DEL from command prompt do not send to recycle bin.
If the above software does not work for you, let me know and I can write a script for you to move all duplicates to a separate folder for your review, prior to delete action.
If I was to write a script, I would leave the source code in code brackets for others to review, just like any other open source code forum (C#, VB, Java, vbscript, PowerShell, SQL, etc...). It is standard practice in any coding forum for programmers.
If it is a compile exe, then of course that is a different story. But as i have shared, it is a script and it is safe to say there are other programmers using this forum too who can review or share.
I may be confused which aint unusual but, as I understand it, you copied the files from your phone to your computer. I cant figure out if you have one original & two copies or one original & one copy. So, I dont know exactly how to word my answer/questions to you.
If you have one original on your phone & two copies on your computer, and you want to delete one of the copies on the computer, I'm with Rick Johnson. Its apparent you know where both copies are because you are apparently seeing two folders. DCIM & DCIM2.
If this is the case, just single click on DCIM2 (that will highlight that folder). At this point, you can do one of two things. Push the "delete" key on your keyboard..... OR you can right click on the highlighted folder & choose "delete" from the options.
That will delete the unwanted DCIM2 folder & all of its contents. The DCIM folder will still be on your computer & you will still have the original on your phone.
