How do you safely remove keyboard dongles?
Old 10-15-16, 12:57 AM
A
I have a logitech keyboard i move around between my pc and an android tv box and am wondering if it's ok to remove it when device powered on? I don't see any way to do the normal safe removal procedure. When i insert or remove it from my android tv, it causes it to reboot.
Old 10-15-16, 01:03 AM
A
This only a reply to subscribe to thread that i forgot to click.
Old 10-15-16, 04:41 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
I have never had a problem just unplugging mine.
Old 10-16-16, 08:27 PM
Received 1,231 Upvotes on 1,179 Posts
You can just unplug it and go.
Old 10-19-16, 10:36 AM
Z
Received 398 Upvotes on 355 Posts
You should be able to just unplug it. The only thing the 'safely remove' does is make sure all the open files are closed. There's nothing inherently 'unsafe' about removing a USB drive unless files are actually being written - in which case you can run into half-saved files and other corruption.
With a keyboard, there's no data corruption issues and no open files. I'd imagine there's an issue with the TV box where unplugging the USB device is causing a minor surge on the USB bus which isn't being suppressed well enough by the USB chips and associated components. I don't know of any solution to this other than finding a better quality box. Sorry!
