computer won't recognize dvd player windows 10
Old 10-06-17, 05:30 PM
K
I am trying to play a cd on my computer or at least download it to itunes but my computer will no longer see the dvd player. I don't think I have used it since upgrading to windows 10. I also tried it on my laptop and same thing. Any good suggestions? Thanks
Old 10-06-17, 06:05 PM
D
Go to system in the control panel. Click on device manager. Is there a yellow exclamation point or red X next to the DVD player? If there is try to upgrade the driver. If that doesn't work, determine what DVD player is installed & download the driver from their web site.
Old 10-08-17, 07:12 AM
H
Received 108 Votes on 94 Posts
This is a common problem, Win-10 sometimes fails to detect the drive, then puts in a wrong registry code.
login as administrator
pull up a Command prompt, i.e. old dos interface
start the registry editor by typing "reg.exe" hit enter
add "HKLM\System\CurrentControlSet\Services\atapi\Controller0" /f /v EnumDevice1 /t REG_DWORD /d 0x00000001
If that's a bit too, technical, you can search on line in cnet or some dedicated computer forums for a more detailed anwer.
Old 10-08-17, 02:01 PM
K
I was able to fix the problem, at least on my desktop computer. I haven't tried the laptop yet. I use the fix that I found with this link. I used Method #4 and it seems to have taken care of the problem. Hope this helps someone else.
https://support.microsoft.com/en-us/...other-programs
