Home Network Device Connection Locations?
Old 09-28-18, 06:15 AM
P
Received 2,014 Upvotes on 1,806 Posts
Does it matter where devices are physically plugged into a network?
I have just upgraded the hardware for my home network. Currently my NAS (server) is plugged into a port of the wireless router. To improve the performance of the wireless router I want to move it to a new location where it is not very accessible so I only want to run one ethernet cable to it. Will it hurt performance if I plug my NAS cable into a spare ethernet port on my modem? Is it best if the NAS is plugged directly into my wireless router?
Old 09-28-18, 09:09 AM
P
I have a spool of cat 5e cable. Is it worth buying a spool of cat 6 over the 5e that I already have?
Old 09-28-18, 11:30 AM
Bob14525's Avatar
Received 74 Upvotes on 65 Posts
Usually modems only have 1 output port. Are you referring to a separate modem and router, or do you mean a "gateway" which is a modem & router in one box?
As for your question regarding Cat5E vs Cat6. While Cat6 is better, since you already have a spool of 5E, I would go ahead and use it. You should get full gigabit ethernet speed over either.
Old 10-01-18, 07:56 AM
A
Received 5 Upvotes on 4 Posts
If you connect your NAS to your modem it may not be on the same network (IP address range) as your other devices that connect to your router.
It all depends upon how your network is configured.
Usually the router provides the IP address not the modem.
Old 10-02-18, 11:26 AM
Z
Received 407 Upvotes on 362 Posts
Assuming you have a reasonable network setup, it really doesn't matter where on your network you plug a device.
Wireless will typically be slower than hard-wired. But whether it's plugged in here or there or in this room or that room, you're talking microseconds or maybe millisecond access differences... nothing you'd ever notice.
