iPad Not Allowing Internet via Wireless Access Point
Old 01-06-20, 12:01 PM
I have the following setup between my house and detached garage.
Actiontech modem/router connected via an ethernet cable to a Belkin wireless router in a detached garage. I have set up the Belkin router to act as a wireless access point using the Belkin's software and disabled DHCP on the Belkin and given it it's own static IP address.
When trying to connect an iPad to the wireless access point , the access point is recognized and the signal strength is strong, yet when I try to get onto the internet, I get a message that the chosen website cannot be reach because my iPad isn't connected to the internet.
I'm sure it is a simple setting that I have missed, most likely in the iPad.
Any help on setting the iPad up (in the Wireless section of the iPad maybe???) would be appreciated so I can use it in my garage on the garage wireless network.
I still want to be able to use the iPad in my house and can currently use the iPad on the house router with no problem and get on the internet, I just have to select the house wireless network.
Thanks
Old 01-06-20, 01:47 PM
P
I think the issue is related to the connection between the Actiontec and the Belkin access point. You should check that you are getting a valid IP address on the ipad that matches the same range as you do when you connect in the house. If the first 3 portions of the IP address are not the same, then the 2 routers are not talking properly.
- Peter
Old 01-06-20, 02:46 PM
Not the issue--As far as I can tell
The first three portions of the IP address are the same on both the Actiontec and the Belkin. The last portion is different on each.
Old 01-06-20, 08:21 PM
H
Check the "gateway" setting on the Belkin.
The Actiontec IP (usually 192.168.1.1) should be entered as the "Gateway" in the Belkin, so that the Belkin knows to route internet traffic to that address.
Old 01-07-20, 04:23 AM
Thanks
I'll try to give it a shot tonight when I get home from work.
Thanks for the suggestion.
Old 01-07-20, 11:17 AM
Z
If you're still having problems, post back with the IP settings on your ipad or a screenshot. IP Address, Subnet, Gateway, etc.
Old 01-07-20, 11:27 AM
Have a contractor coming to the house in a few days, so a lot of prep work to do before they come so this issue is dropping down in priority, however I will not let the suggestions for resolutions go untried.
Thanks to all and I'll advise.
