older external speakers, older computer
Old 01-30-24, 09:21 AM
trose348's Avatar
Received 1 Upvote on 1 Post
Question older external speakers, older computer
I've been troubleshooting why I don't have sound on my Lenovo older computer. I've tried to update drivers etc. & I have older Creative external speakers. It's just a jack (light green) & an adapter that I plug into the electric. What I've noticed when I've been trying to trouble shoot is: if I slowly unplug the adapter or the electric plug, I will actually hear the sound for 2 secs. This is mindboggling! I used to have sound on this & just can't seem to fig. this 1 out. Anyone know? Thxs
Old 01-30-24, 09:56 AM
P
Received 2,186 Upvotes on 1,956 Posts
My first guess is a bad plug or socket. I'd first try a different set of speakers and see if they work.
trose348 voted this post useful.
Old 01-30-24, 02:27 PM
Received 3,990 Upvotes on 3,581 Posts
Are you troubleshooting the computer or the speakers ?
If you unplug the speakers.... the computer should have audio.
If you don't have audio directly at the computer... the ext speakers won't work either.
W
Received 63 Upvotes on 55 Posts
Check the speakers to see if any of them have a volume knob. If so, turn the knob to see if that helps.
Old 01-30-24, 06:02 PM
trose348's Avatar
volume is turned up, I get sound if I slowly unplug the adapter for about 2 secs. I am not getting sound on the computer either. I plugged in the speakers because I don't have sound. I had sound 2 mons. ago. I bought a new computer that is having issues & am having to use the old computer until things are worked out with my new computer. No sound anywhere. I just thought it was interesting when I slowly unplugged the adapter, I'd get about 2 secs of sound........whatever music I am playing.....2 secs. It's a conundrum.
Old 01-31-24, 06:51 AM
Shadeladie's Avatar
Super Moderator
Received 393 Upvotes on 321 Posts
Have you checked your sound settings? There's probably something wrong in there if you're not getting sound from your computer either.
Old 02-02-24, 11:03 AM
trose348's Avatar
Update! I moved my old computer back while the new 1 is in the repair shop. After I did this & plugged in the speakers to a dif. socket, they are working just like before. Go figure!
Old 02-02-24, 01:35 PM
Z
Received 126 Upvotes on 117 Posts
If you were using front-panel audio, that should be connected to your motherboard via a cable. That cable connection can possibly come loose at the motherboard (I've accidentally and unknowingly disconnected mine with fat-fingers while doing some work inside the box).
But if you switched to rear panel audio that would be unaffected and should work. Maybe yours was hanging by a thread at the motherboard connection for some reason - and one day - one more little vibration and the connection is broken.
Can't hurt to open the box and look anyway. Just a thought.
Old 02-03-24, 01:54 AM
Received 50 Upvotes on 46 Posts
Problem could be combo jack compatibility. Take a look at a 3.5mm splitter jack and see if it sounds like a potential solution.
Old 02-03-24, 10:09 AM
Z
That's right. My bad. The front panel audio is usually headphone, microphone or a combo. Not for speakers. When the OP said he used two different connectors to try the speakers, I jumped to the conclusion: front panel, rear panel. But that doesn't make sense.
Still, I would open the box and inspect -if that's possible. Might not be easy with the off-the-shelf Lenovo though. Would not want to create a problem.
