Ground level deck
Old 03-23-16, 12:47 PM
A
Ground level deck
Trying to build a deck so there is only one step down to ground level. Looking for ideas besides your typical beam, joist, deck board structure that won't take up so much height. Thanks
Old 03-23-16, 02:12 PM
Received 854 Upvotes on 748 Posts
Welcome to the forums!
It's not a great idea to build a wooden deck that close to the ground. The restricts air movement under the deck making it harder for it to dry out when it gets wet ..... which often results in a short life for the deck.
Old 03-23-16, 05:21 PM
A
Thanks!
I kind of figured that. Am reworking the whole thing to be higher off the ground.
Old 03-24-16, 02:47 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
What dimensions will the deck be? It will make a difference as to what size lumber will be required. Your frost line is also quite deep, so your footings may need to be as deep or deeper than the water line shut off at the street, which is probably 3' or so. Your electrical service is most likely underground as well as any gas you have, so be sure to call 811 for a locator service (free) just to make sure you steer clear of them when digging.
Old 03-24-16, 08:10 AM
Received 1,273 Upvotes on 1,213 Posts
Keep in mind you want a step down from the house to the deck as well to avoid snow and water being up against the door threshold.
